I'm having trouble with my SV830, 10 years old, approximately 300 hours, well kept.
Was running bad last year, pulled spark plug wires & learned one cylinder was out. Compression test showed blown head gaskets.
While replacing valve covers, discovered both sides had bent push rods. Replaced head gaskets & push rods.
Ran great for an hour, then lost power again - pulled plug wires & learned that one cylinder was out. Pulled valve covers and discovered that one intake valve had poked through the rocker arm (pushrod pocket fractured and became a hole). No bent push rods. Looking at the valve guides, nothing appears to have moved. Bought 4 new rockers and will replace & try it again. If that results in bent push rods, then will replace heads and possibly lifters.
What happened and does anyone have suggestions?
Any way to test the lifters to see if the plunger is frozen?
Thanks!
Thanks!
