B Butch1957 Active Member Jun 24, 2026 #1 I am in need of an engine harness Local dealer states this part is discontinued Any input as where I can find a used one. ? Thanks
StarTech Lawn Royalty Jun 24, 2026 #3 Per IPL it was 32 176 14-S. That harness has been out of production since at least July 2024. It is repair the current harness if not totally burned up or find one in the local mower engine graveyard.
sgkent Lawn Addict Jun 25, 2026 #4 I do not know the part nor is there one nearby to inspect. Lots of similar part numbers. There are some used sales on Ebay listed as Kohler stator and module, Kohler stator and harness, etc.. or example here is one. You might do a search there and compare parts to what yours looks like. https://www.ebay.com/itm/287368539771?_skw=kohler+#237878-S,+REGULATOR+AND+WIRING+HARNESS+FOR+PARTS&itmmeta=01KW05PHATD4Y9P0TN0JV24HVS&hash=item42e87fee7b:g:CJQAAeSw51NqHcrZ&itmprp=enc:AQALAAABAGfYFPkwiKCW4ZNSs2u11xAzAc3dKASnubYUzglFWxOIs/Ml20I92PyCwuJt8lChrWPT3qk8pA5xeaYyZEYvX8dzRWMplanGziODj/SYR8CrvyDf7Zx2kkJExWezP8B4i9bN6TCx0uIho4YaoDWSUk5+ij4GfIzHpHip2DpUhZa8HJ2M8kth9sQljTxnD7ubEG4PUV1p4B9PRvBqxBOjY1WjHwgRIS1whoWLPoCPxK/Wvb/lxCC25x3CQxaUIyGsujwFr6NrxZUcyONb3/mcV9QmMrlBA6fspjbIWrwg8PvHfsqgTC1dRYl2q8hS0YaQjjH+x1jA4pUzhnJJmcVpCQY=|tkp:Bk9SR9KV2oXgZw or https://www.ebay.com/itm/403961924264?_skw=kohler+%23237878-S%2C+REGULATOR+AND+WIRING+HARNESS+FOR+PARTS&itmmeta=01KW05PHAV6SG1XEBZX1VC64G8&hash=item5e0e01caa8:g:aioAAOSwpNVjWZtc&itmprp=enc%3AAQALAAABEGfYFPkwiKCW4ZNSs2u11xCTo8ZlHyI%2B0LmPasSXL9Xw%2BAp6GT6kgvzeLBNvRHl3yzp5Jl40I9rsqKpvVuA5DhqwxsPNxZ8D1vHCzO6CzW6Utp7hPcqZ0Xplse44gppASwIIisLDKxpxEfTGUFuN%2B2O8QqQGiCvKjH6Wh9kk7iKyXKsgJzablSapXkfLMFmpd7V2fLFleaO1FWH3Ul53dURveJRMBIXodng5906HSdXkcWZQkT7ffuRAlESsXWkf%2BAcVK9wqxowWQV%2BO4xjaglvmZbpb4lbjj3qmHV2xHu4JPAaBLDB7RPNolL3Ea%2BXfs1QqC7lYorkpGUVb%2BU2FDVPd1ruHzwt6ejXtt%2BJFiWQD%7Ctkp%3ABk9SR9KV2oXgZw
