Kohler SV 590S courage engine wont start
Georgep
I reset the valves to spec. and has good blue fire, getting gas but will not hit a lick. Tried starting fluid and still nothing.Any IdeasThe mower is a toro Zx 4200 timecutter Model sv590-0212
Hexxus
I had a problem like this but on a 4 wheeler. Had ALL the things it needed to start but wouldn't. My dad tells me that it has something to do with the engine itself, iirc it had something to do with compression or the cylinder/piston is scored and the oil helps make a better seal. What he did was spray some WD40 into the intake and then tried to start the motor while choking it at the intake with his hand, it fired up.
Pull the blower housing off and check the flywheel key.
the rectangles in the flywheel and the crankshaft should come together to make a perfect square.
