Kohler short block matching help, please!
lndaddy
Hello all. New to the forums. Thanks for the add by the way. I have a Toro Timecutter Z5000, with a Kohler Courage 21hp engine. I recently developed a crack in the case, due to loose top cover bolts. I'm looking to get a replacement short block, as the rest of the parts are ok. With all the model numbers out there, I'm kinda confused on what I need.
Here's the #'s on my engine:
Model SV610 (20 522 04)
Spec SV610-0020
Build date 11/2007
I found this short block a a decent price for sale:
Model 20 522 13.
The site list compatible engines anywhere from SV610-3200 to SV610-3216. Is this short block what I need? I can't get a definate answer on the net. Any help would be greatly appreciated.
Your engine calls for the 20 522 15 shortblock. It looks like the 20 522 13 uses a different crankshaft.
