PTmowerMech
Sorry, I don't have the model numbers. But this may be simple enough (for the small engine guru's)
6.75hp (ohv) Kohler. The problem is when you pull the rope, there's one spot in there where it catches, and pulls the mowers front wheels off the ground. The engine kill brake isn't toughing the engine. There's only a very slight clearance between the flywheel and the brake. But still not catching. I thought that's what it was at first.
What I have to do, is pull the rope out til it get's to that hard spot, let the rope retract, then start from the hard spot. It's almost like the engine's compression release is broken on one with an actual electric starter. But this is a pull start.
Any idea's fella's?
Any idea's fella's?
