Kohler Model # CV16S - Won't Fire/Turn Over
Jrichbrew
Does not seem to be getting gas, took fuel line off of the outlet of the fuel pump and gas does not come out when trying to start. Believe it may be the fuel pump so want to replace. Anyone know the model number for this fuel pump?
pump?
:welcome:
If it is a impulse pump it dose not matter any 1/4 one will do.
Some are better than others but they rarely give any grief.
Buy it from a real shop and you will be fine as there is a lot of stuff that engine companies rejected being flogged off on line.
Try blowing back down the fuel line from the imput side of the pump.
You can get a lot of debris in the fuel tank forming a plug in the outlet cutting off the fuel supply
