Kohler Maintenance Pack
They have held up fine. I took them out the other day to clean and gap them. Gap is .03
Found this interesting chart with some good info on the codes for the spark plugs.
https://online.flippingbook.com/view/17923346/4/#zoom=true
I am thinking about using some BPR5ES. Only reason I would be hesitant is because they are 'P' projected insulator type which is quite a bit larger sticking out of the engine. My thinking is that it shouldn't make a difference in the operation as more insulation shouldn't hurt anything? Heat rating are both '5' (Medium) and thread reach 'E' is 19mm, 3/4" so internal clearance is good.
Seat: Flat​
Seat: Flat​
Thread Size: 14mm​
Thread Size: 14mm​
Heat Range: 5​
Heat Range: 5​
Resistor Type: Yes​
Resistor Type: Yes​
Hex Size (in): 5/8 Inch​
Hex Size (in): 13/16 Inch​
Washer Included: Yes​
Preset Gap (in): 0.036 Inch​
Thread Reach (in): 0.750 Inch​
Ground Configuration: Standard​
Ground Electrode Core Material: Nickel​
Number Of Ground Electrodes: 1​
Center Electrode Core Material: Copper​
Center Electrode Tip Material: Nickel​
Ground Electrode Tip Design: Standard​
Approximate Resistor Value (Ohm): 5000 Ohm​
Insulator Height (mm): 50.5mm​
Insulator Height (mm): 55mm​
Electrical Terminal Type: Non-Removable Nut​
Electrical Terminal Type: Removable Nut​
Center Electrode Design: Standard​
Service Number: BKR5E​
Service Number: BPR5ES​
BKR5ES
