Kohler Magnum 18 opposed twin spark issue.
Rus A
Can you check the spark by unplugging the wires from the engine and spinning it? I put spark testers on the wires & plugs and turned it with another engine. Nothing. I know this works with some engines that have built in alternators. Usually 3 wire plug on them One for
the kill switch and 2 for the charging system. It might be that the magnets on the flywheel are dirty/rusty too. Any suggestions out there? Also do these cylinders fire alternately or at the same time?
see the reply to your first post https://www.lawnmowerforum.com/newreply.php?p=316186&noquote=1
Please start a new repair thread in the kohler section.
Catherine
LawnWorld Support
:welcome:
Welcome to the forum!
Hopefully, you're getting some help already in your other threads :smile:
Flintmotorsports
welcome to the forum
check out i save tractors .com for any antique engine parts.
