edwinthird
- Jun 15, 2015
- 3
- 5
kohler 18 hp magnum on cub cadet 1862. ignition module problems. replaced original module due to shutting down when hot. worked fine almost a whole season. must pull the engine to get to the module. Started acting the same way. pulled the engine and cleaned the flywheel magnet and the module surfaces and put it back together. I am cutting about two acres. after the second cutting it shut down again. would like to know if the module would go bad that quick and if there would be any difference in the manufacturer of the modules as there are various prices for the modules #5258402s
