I need a flywheel and stator for my Gravely 16G, with the Kohler Magnum M18S engine.
The magnets came loose, and damaged the stator, so both are needed.
Part numbers are:
Flywheel= 52-025-36-S
Stator= 237878
From what I can find, the Flywheel is no longer available, but the stator appears to be pretty common and used on several Kohler engines. If I could buy the magnets (3 of mine came loose, and 2 were destroyed), I could do the JB Weld repair, but I don't know where to find replacement magnets for the flywheel, either.
HELP !
I'm near Cleveland, Ohio, 44149
thanks
Part numbers are:
Stator= 237878
HELP !
thanks
