Kohler M18S Flywheel and stator WTB
powrguy
I need a flywheel and stator for my Gravely 16G, with the Kohler Magnum M18S engine.
The magnets came loose, and damaged the stator, so both are needed.
Part numbers are:
Flywheel= 52-025-36-S
Stator= 237878
From what I can find, the Flywheel is no longer available, but the stator appears to be pretty common and used on several Kohler engines. If I could buy the magnets (3 of mine came loose, and 2 were destroyed), I could do the JB Weld repair, but I don't know where to find replacement magnets for the flywheel, either.
HELP !
I'm near Cleveland, Ohio, 44149
thanks
With something that old, you will have to be lucky for that. If you don't have an electric pto, you could just remove the alt and all of the magnets and run it like that until you found what you were looking for. You would have to put on a battery charger every few months or so.
