goosemasterkl
- May 2, 2014
- 125
My brother in law has a Scag Liberty Z with a Kohler KT725 engine and it won't start sometimes. Battery is fine, checked all safety switches and seat and brake switches and they're testing ok but the engine won't try to start with the key ignition. You can hear the fuel Solenoid click when you turn the key on and the pto clutch will click when you pull the switch on and off but it won't try to start. It will start when you turn the key on and jump across the solenoid. Please Any Suggestions!!!!!
