kohler KT725 - 3055 22 HP 7000 SERIES ENGINE OIL SEAL LEAKING
DAVIDGROSS
  • / kohler KT725 - 3055 22 HP 7000 SERIES ENGINE OIL SEAL LEAKING
I HAVE A OIL LEAK ON THE BOTTOM OF THE ENGINE, WHAT ALL IS REQUIRED TO REMOVE THE OIL SUMP PAN TO REMOVE OIL SEAL AND RE INSTALL SUMP PAN,
DO I NEED TO BE CAREFUL WITH CRANKSHAFT AND CAM SHAFT TIMMING MARKS
Why over complicate the replacement. Oil seal is replaceable without disassembly of the engine. Just to be careful not to damage mating surfaces.
