kohler k181s starting issues
The Maddox
hey everyone, got some issues with my first older mower. its a 1970 john deere 110 with a k181s engine. to make it easier im going to put the problems in the order they happen haha
First problem: turn the key and the engine turns and turns and turns, but will almost never start up. like it isnt getting a spark. when it does start it runs great but im terrified to turn it off, seeing as it probably wont start back up
problem 2: after trying repeatedly to start it(and failing), it decides that it doesnt want to do anything at all. and i mean nothin'. the only thing that moves is the battery gauge
problem 3: oh boy, i finally got it running this is gunna be great!!! 5 minutes in it turns itself off. seems like its bogging itself out or running out of gas. sometimes i can catch it by either A: shaking the battery or B: pressing the clutch for about 30 seconds. but half the time im not able to catch it.
this is my first mower and im already in love with it. i just want it to work properly. can anyone give some advice and help me get this antique back on the lawn?
We may need to start with a compression reading. Most if all your problems can be linked to low compression, so lets start there.
so compression was a great place to check. especially since the threading for the spark plug was almost non existent. stratches done the cylinder and everything else. i think im going to just purchase a new engine. where would i find a k181s?
No replacement for the K181 available, no short block either. About the only option would be to have somebody that knows what they are doing to overhaul the engine.
If it's got the battery ignition coil (mounted externally), that might be your problem? Make sure when you turn the key to ON position, the + terminal on the coil should have 12v if that's the way it's equipped?
