Kohler K161 not getting spark
ghost1
Rebuilding an older K161 and it will only spark once in about five pulls. It has new points and condenser. Can coil be causing the problem? I thought they either worked or didn't.
Do you have a battery ignition, or a magneto type? Got any pics? Is this the one that you were trying to figure out what it was?.
If so, you better throw up some pics......
I had the new one on, but was checking to see if it might have been a bad condenser and replaced old one with same results.
Thanks for info. Gap is set at .020 but will adjust to .018... No kill wire on this system.. Point cover has button to push. Can a coil going bad produce this kind of symptom???
