Hi all,
I recently swapped the engine on my Craftsman T3000 mower from Briggs to Kohler. Before you ask why I would swap out the 20hp Briggs with a 13.5 hp Kohler... that stupid little fuel shut-off sylinoid failed and allowed a bunch of gas to leak into the crank case and my son never told me there was an issue... months of running the motor with gas diluted oil has caused the motor to start knocking so I bought a John Deere mower for $100 to snag the engine from.
Here is the issue. The Craftsman mower is a gravity feed fuel system and the Kohler engine has a fuel pump as it came out of a John Deere mower.
When I first fired it up it ran great and I was mowing until it ran out of fuel. Knowing that there might be an issue I ran the fuel line out of the tank (which comes out the bottom of the tank) up high over the tank then down to the pump trying to cut down on the weight of the fuel pushing through the pump. it seemed to work until I ran out of fuel and filled the tank about half way up. Now all it does is flood the engine.
I suspect that I only had a few cups of fuel in the tank before and there wasn't much gravity weight pushing it through the pump.
Anyone know how to make this combination work?
I tried jerry-rigging the setup by strapping the fuel tank all the way at the back down on the hitch plate and running the fuel line uphill to the pump but the problem of flooding still happens.
