Kohler engine starter engages but engine will not turn
ssgshoe69
  • / Kohler engine starter engages but engine will not turn
Help,
I have a craftsman mower model No 917.259547 with a kohler 15.5 hp engine model No CV155. The problem is I went to start the engine but the starter was not working. Charged battery nothing. Got multimeter out and found no voltage at starter. After further testing, starter solenoid was not passing the voltage. Replace starter solenoid. Starter engaged but engine would not turn over. Tried turning engine at crank but would not move. Removed spark plug and engine still would not turn. After removing top cover of engine to look at things I grab the flywheel and I could turn engine. Attempted to start engine and it started right up. Put everything back together and guess what, engine would not turn over. Help
Fish
Double check your battery posts, they may be reversed!!
EngineMan
"Attempted to start engine and it started right up." was this by hand or by starter motor..?
Fish
Clean/brush all posts and terminals.
GetTechnicalWithJd
Help,
Sure you haven't got a flywheel cover bolt that it too long and is perhaps binding on the flywheel?
It only turned when the cover was off that's why I'm suggesting it.
