I have two John Deere mowers a F620 60" 7 iron deck with Kohler 20 hp CH20S-64556, I have a John Deere 23 hp F687 with a Kohler CH23 or 680- both the same mowers orginal engines. I need new engines looking a the CH680-3081 which is a Kohler engine made for John deere.
Question: Does anyone know what equipment the CH680-3081 is made for, or is a basic engine for john deere which may need modification?
The recommended engine made for these models are at least 600.00 more in price over the recommended engine.
I have the front pto shafts for both engines that bolt into the front flywheel, and I do not use the rear pto.
does anyone have experience using alternate Kohler engine on John deere Z trac and what can I expect if I use the cheaper Kohlerler CH680-3081 or another model , does anyone have any recommendation or advice,it would greatly appreciated
thanks
thanks
