Kohler engine no spark till coasting.
mcostello
I have had an Ariens 16-h garden tractor with a single cylender 16 Hp engine. No problems for at least the 2-3 years We have had it. Last week it started and ran like normal. It always has started when I quit cranking and the motor starts coasting. I noticed this and it has never been a problem, I never had to diagnose it. Now I checked the spark and noticed this behavior. It does not even try to start even with starting fluid. Compression and all else seems normal, just not even a pop. Anyone have any experience like this? Where to start looking?
lets start with the model and spec of the engine on your mower. The 16 hp could be a K series, KT series, M series, CH or CV series, SV series. So without the engine info we are just guessing.
Assuming K341 then What is the specification number of the engine so we don't have to guess. Kohler used both a battery ignition and a magneto ignition on their K series engines.
My suspicion is it is not sending power to the coil with the key in the start position. Could be faulty key switch, could be somebody replaced the key switch and now has the wrong switch. Never saw it with the battery ignition systems but is fairly common with the Kohler engines with the fuel shutoff solenoid not sending power to the solenoid in the start position but works fine in the run position.
