Kohler ECV 730 - bogs under load
hlw49
This is there trouble shooting guide out of the service manual for this engine. Engine Loses Power ● Dirty air cleaner element. ● Engine overheated. ● Excessive engine load. ● Restricted exhaust. ● Faulty spark plug(s). ● High crankcase oil level. ● Incorrect governor setting (on engines equipped with electronic throttle body governor is digitally controlled and not adjustable). ● Low battery. ● Low compression. ● Low crankcase oil level. ● Quality of fuel (dirt, water, stale, mixture).
mczar07
Thanks for the info. Iv'e been going through it as well and have done the following:
- installed air filter, changed oil and filter to proper level, checked compression, new spark plugs, new coils, reset the governor adjustment, charged and load tested battery, changed fuel, fuel filter, fuel pump, injectors, ECU reset, TPS relearn, new O2 sensor. MAP sensor is on the way since I damaged it when reinstalling it. There was a smashed O-ring on it which could have been causing the air leak, I just figured that it would have more of an issue at idle when vacuum is at it greatest. At idle, it runs perfect only has an issue when you load it up at high RPM.
hlw49
When you are saying CEL I assume you are saying check engine light. Does this mower have a MIL light malfunction indicator light that will blink codes or are they calling it a check engine light. Anyway will it blink codes?
mczar07
It will blink codes if I unplug a sensor but there are currently no codes flashing on the MIL or CEL as I was calling it. I changed the broken map sensor with new and still has same issue. I'm not sure what else to do.
hlw49
If this mower is running that bad and is throwing no code how are you trying to read the codes.
mczar07
There aren't any codes unless I unplug a sensor. At that point, I read the flash codes from cycling the key to get them to flash. After I know those codes aren't causing an issue, I do an ECU reset and a TPS relearn
hlw49
What procedure are you using to read the codes????
mczar07
the procedure from the manual.
1. Check that the batt ery voltage is above 11 volts.
2. Start with the key switch OFF.
3. Turn the key switch to the ON and OFF, then ON
and OFF, then ON, leaving it on in the third
sequence. Do not start the engine. The time
between sequences must be less than 2.5 seconds.
Check computer ground and power.
mczar07
new map sensor replaced. I ended up getting the Kohler diagnostic software for the live data views. looks like when the engine goes into "power enrichment" in the ecu, the issues start to happen until the throttle is dropped down and "power enrichment" becomes disabled.
