Hi,
I have an early Simplicity ZTR 14-44(I think) with a Kohler Command CV 460S-16 hp engine. It's the one with the steering bars on the center column. It has been abused (not by me, of course) but still does the job. It's amazing how it putts through tall, wet grass if the blades are sharp.
It does have a problem, however. The engine revs extreamly high and has poor response to the throttle lever. It wants to either idle or go wide open, very hard to find middle setting. Also, I have to manually adjust engine speed if I go up a hill or hit a patch of high grass. The same goes for going down hill or returning to lower grass, the rpm's scream until I adjust the throttle. It started doing this gradually, it would run fast for a while and then settle down after 20-30 seconds. The occurences became more often and it would act up for longer periods of time until it just never went back to normal.
Repair guy says he's seen this many times before, it needs a new carb-the old one is not repairable. He says the governor is fine, just give him $150. to install the carb and it 'll be back to normal. This sounds fishy to me.
Any insight from the forum?
