Hi to all. I'm trying to refurbish this old JD that my mother used. I've got it running and all the belts replaced. My situation now, and for quite a while, is that the battery isn't charging. I am getting 28 vac out of the stator, which I think is normal. The voltage/rectifier only puts out 11-12 volts. I've tried three different regulators, the original, a brand new one I bought, and one off a friends engine with the same 41 403 09 regulator which is working fine. All three put out the same 11-12 volts. I have checked for bad grounds, found none. Everything I've read, says if I'm getting aroung 30 volts ac from the stator and less than about 13-13.5 volts dc from the regulator, the regulator is bad. I can run it with a fully charged battery for quite some time, then the amber battery light comes on. Does anyone have another idea on this? Thanks for any and all advice? Roy
