shauncavett
One detail I had mistaken - the throttle is staying open, not closed.
I attached a few more pictures showing the linkages @ low throttle, choke, full throttle, and back to low throttle.
The governor arm moves freely, but from what I see it should move back to close the throttle & it doesn't it. But, even when I move the throttle lever from low to high to low - the linkage doesn't move.
One picture I added shows the spring on the throttle linkage.
