J jb4249 Member Joined May 30, 2012 Messages 37 Apr 17, 2020 #1 I picked up a nice Troy Bilt with the Kohler Courage 22HP engine. I have been told that this engine is prone to failing and does not have a good reputation. What have you guys experienced with this engine? It is a 2012
R Rivets Lawn Royalty Community Leader Joined Mar 11, 2012 Messages 16,283 Apr 17, 2020 #2 Biggest problem is that the sump bolts come loose. Take the shroud off and check all bolts holding the cover to the block.
ILENGINE Lawn Royalty Community Leader Joined May 6, 2010 Messages 12,021 Apr 17, 2020 #3 The single cylinder was that one with most of the issues. The twin courage is a decent engine, but did have some starter problems.
