smallengineguy
- Mar 15, 2020
- 5
- 27
Hi all,
I have a Cub Cadet rider with the above engine. I removed the rocker arms to address another issue. Now the engine will start but as soon as the lifters pressurize, I lose compression (holding the intake valve open). After the engine sits it'll start but same issue. Rocker stud adjusted to 100 in lbs. I can't adjust the clearance obviously. Do I need to remove the lifters and bleed them down? Can I do this without removing the head? Thanks in advance for the replies.
