Kohler Command 20 smokes & burns oil only after warm up
John Trox
  • / Kohler Command 20 smokes & burns oil only after warm up
Maybe I’m not seeing the latest responses but the next question is can I keep it full of oil for this summer and tear it down this winter?
Scrubcadet10
Moderator
Staff member
You should be able too.
when you tear down, if you have a machine shop, or engine building shop close by, take the block to them and have them mic the cylinder bore. may need an oversize set with oversize piston.
John Trox
Can I assume it’s the rings and keep oil in it for the summer and rebuild this Fall?
John Trox
Thanks for responding. I wasn’t seeing the next page.
