Kohler CH20S - access front spark plug?
TomCooper
I have a Toro commercial mower 74180 and went to change the spark plugs.
The rear plug was annoying enough because I had to remove the battery to get clearance to get it out, and the front is worse.
I was able to pull the front plug, but could not thread the front plug to tighten it.
Worse, I dropped the plug between the block and the heat shield and am having a devil of a time trying to fish it out.
Is there a trick to this? What am I missing?
Auto Doc's
A commercial mower is a dealer level machine if you can find one in your area. They are not cheap and not repair friendly.
