kohler carburetor problem
dartlover67
Amazing. I just logged in for the same exact issue. Kohler CV Series.New Carb,all new fuel lines and Pump.Starts and shuts down,Looking for the anti-afterfire solenoid.
Auto Doc's
The after-fire solenoid is in the bottom center of the carburetor fuel bowl. Often times the connector pins are a poor fit, especially on aftermarket carburetors.
Turn the key on without cranking the engine, a faint click is usually heard at the carburetor if the solenoid is working. If no click, wiggle the wire connection gently and see if it clicks on and off as you move the connector.
Sometimes the female pins can be gently tightened with a small pick tool to correct the problem.
dartlover67
Thank you, I'll
check it now.
dartlover67
Thank you once again.It fired right up.Loose connection on male/female plug.Doc,ever run into this issue.When I leave the brake out the motor shuts off.Is there a limit switch on it or something like that?
Auto Doc's
Hi Dartlover67,
Are both of the operator levers in the rest position?
dartlover67
I'm new to this old tractor Doc. Ill have to check.My brother gave it to me at the end of last season and I'm learning slowly.Operator Lever in the rest position refers to what?
Auto Doc's
Can you attach a picture. Your info says it is a zero turn. What brake are you referring too?
dartlover67
Just got it Doc.It was the safety switch.Cleaned it and it working fine.I cant thank you enough for your guidance.
Auto Doc's
Sometimes it is simple but seems difficult. The KISS (Keep It Simple Silly) principle typically applies.
