Good 1 Brian
I read the service manual on my Kohler 7000 Pro can't find anything about the first oil change just said at 25 hours my question is the a need to do the first oil and filter change sooner ?
Yeah,,metal is metal...so I always do my first change between 5-8 hours,,then 40 to 50 there after on all my new motors/engines.I read the service manual on my Kohler 7000 Pro can't find anything about the first oil change just said at 25 hours my question is the a need to do the first oil and filter change sooner ?![]()
The initial oil/filter change for my Kohler 7000 was done yesterday. It also looked like break in oil (Yellowish green looking stuff)same engine on hustler and they recommended 5 hrs too. just did mine before vacation and it looked like a break in oil
The Hustler Raptor SD Operator's Manual = Section 4 page 4
"Change the engine oil and filter after the first 5 hours of operation
and then per the engine manufacturer's recommendation after that."
Then goes on that "if operated in extremely dirty conditions, then it is
recommended oil be changed more frequently."
