Would be normal for the 20 amp charging system. May need to what looks like a bad regulator, but with new regulator we may need to do an amp output test to find out how many amps the system is putting out, and to make sure the system is not overloading the regulator causing it to burn up. The claw type amp testers would work best for this test.
The short that was create when the choke cable welded inself to the regulator could have overheated the wires someplace in the wiring harness and now a couple of wires are fused together causing a short, or causing an excessive amp draw.
