Buck Jordan
- Oct 3, 2019
- 1
I have a Simplicity CV20. My engine will not sop unless choked to death. This is not good for longevity of the engine.
I have attached new wires to the coils and then to a kill switch that goes to a good ground. When I throw the switch it sounds like one cylinder stops but the engine still runs. Is it possible the coil on the running cylinder is defective ? I also pulled 1 plug wire at a time, through the kill switch - one plug off and 1 on killed the engine BUT with the other plug disconnected and the first one plugged in the engine still runs with the kill switch thrown to off.
