kohler 17 h.p pro
dwint
I bought a used craftman with a kohler pro hydraulic valves.its turning over really hard when I start it and was hoping the valves could be adjusted but I took the valve cover off and theres no adjustment.when I turned the motor over by hand there is no gap in the valves at all.can someone tell me whats going on.i have a new battery and briggs if this happens you adjust the valves.is my starter shot
mechanic mark
post model number from under seat as well as all numbers from engine data plate.
dwint
this is on the engine 3khxs.49026b
reynoldston
It could have carbon build up on the heads and pistons.
dwint
that would give it too much compretion correct?
