This engine was put in an old John Deere lawn tractor. I cant find the pulse line for the fuel pump. I have been using the vent off the valve cover that should be connected to the air cleaner. Its the only place I can find on this motor. Anybody know where the actual pulse line is? Not sure if its a good idea to use this port for oil blow by or even a solid consistant pulse for the pump
