Koehler Courage starter motor - remove hog ring.
Trout bum
I need to rebuild the bendix unit on my Kohler Courage lawn tractor motor. The motor is a Johnson Electric part number 2009805 08005. I have the repair kit and my question is how to remove the hog ring holding everything in place. Thanks in advance. Jack
Yes, they are a pain in the %#&6/; to remove. I use a large side cutters to get under one end and pry them off. WATCH YOUR FINGERS. It takes practice and patience, plus about half dozen tries.
Put a towel or something over the ring when removing, because it might go flying off, never to be found again. Ask me how I know.
If you can find an old school auto machanic they may still have the puller for those rings. I had the puller because back than we rebuilt starters and replaced many of the drive gears. The puller served as the remover and the installer all in one.
Thanks for the reply. But I still can not figure out how to get a very small tool(s) between the shaft and the top “collar” to remove the clip. There is only about 1/8” gap between the two parts. I originally thought the top collar slid down the shaft to expose the clip, but that is not the case.I am going to try a very small needle nose pliers next. Jack
Usually you have to drive the collar down with a socket of the correct size as the ring locks the collar in place.
Have you tried to remove it by rolling it off with a side cutter? It works just takes time.
