dougmacm
- Jul 21, 2018
- Threads
- 11
- 162
As mentioned in another thread, I bought the Kobalt 80V 22" Brushless Snow Thrower back in May of 2019 and it came with a 5Ah battery. Later that same month I bought the KHB 2580-06 Brushless Blower that came with a 2.5Ah battery. Used the 5Ah in the blower a few times to give it some exercise, but being quite a bit heavier than the 2.5Ah, it was not ideal in the blower. The 5Ah battery finally got used in the snow thrower last winter maybe a 1/2 dozen times and it worked just fine and had been storing it fully charged ever since the last snowfall.
Fast forward to last Friday, I bought the KMP 6080-06 Self Propelled Lawnmower that came with a 6Ah battery. My thinking here was having the mower, the 5Ah battery could get year round use alternating between it and the 6Ah and same would be for the 6Ah getting use in the winter months too.
The 6Ah was just partially charged, so I put it on the charger and grabbed the fully charged 5Ah from the Snow Thrower and put it in the mower.
Now onto the problem ... the battery shows fully charged by the lights and if you put it on the charger it will just glow green saying it is fully charged.
Voltage across the terminals reads 81.2V (the new 6Ah fully charged reads 82.2V and the 2.5Ah reads 82.8V).
Put this 5Ah battery into:
Lawnmower, it will turn the blade motor for a couple of seconds then shut down with a 5 beep sequence followed by a 4 beep sequence.
Snow thrower, it ran motor for a few seconds then beeps constantly
Blower it will blow for a couple of second then shut down (no beeping)
All the 80V Greenworks/Kobalt battery issues mentioned online are low voltage conditions where charger does not recognize and will not charge, saw no mention of my issue so figured I'd post here to see if this is familiar to anyone.
Battery has a 3 Year Warranty and manual states to either bring it into the store where purchased for exchange of call 1-888-3KOBALT. Rather deal with someone face-to-face so I'm going to my Lowes tomorrow to see if they will order me one in to exchange (they only have the 2.5Ah in stock).
Doug
Doug
