PTmowerMech
- Apr 16, 2018
- 396
- 3,018
@ Stens, I found the gasket set. But not the entire set with needle & screen.
This one I'm working on, Seems to flood out when I pull the trigger. Opening or closing the H, (nor the L) work. So I took it apart and found the gaskets on the wrong side of the diaphragms and the meter too high and no screen at all. Got that sorted out. Plus a new gromit and fuel lines, cleaned the filter pressure checked it and it was good. Next thing I know, it's not priming. Maybe once every 50 primes, it'll suck some gas up into the primer.
Is that a sign a check valve is bad?
UPDATE: It'll prime when it's on it's side. But ONLY when it's on it's side.
