Kill switch issue. HELP!
deegz
Hi all,
I have a Briggs and Stratton 550 series (158cc) 4 stroke engine on a Victa mower. Recently the mower has not been shutting off when I turn the lever to stop. If I reached down and turned the swivel with my hand it would sometimes shut off but other times not. I figured it was due to poor contact with the kill switch located under the swivel plate. I have just installed a manual killswitch made from a marine killswitch. It is now killing every time I flick the switch, but the mower is now revving high. Why is this? what has my alteration done? How can I rectify it? I thought it was as simple as no earth = mower runs, earthed coil wire = mower dies. How is RPM regulated??? obviously I have bypassed this regulation......
Photo1. New Earth point for killing engine.
Photo2. New manual killswitch located above old cable lever that controlled the swivel plate
Photo 3.Swivel plate - old killswitch contact point is that little vertical piece protruding up towards the back of the base plate.
Photo 4. Wire from Coil? which I have connected to the new killswitch on the handle (see pic 2)
deegz
Ok so I had another look at it......... The new earthing wire was up against the governor pushing it to rev harder. I rerouted the wire and it is perfect!
KennyV
WELCOME to These Forums...
Glad you located the problem, as you have discovered the coincidental happen chance can inject unpredictable outcomes...
:smile:KennyV
