Kickback
Richard B
Hi All
I'm new to mower repait so probably missing something.
I have a Mountfield SP554 with B&S SV200 and I'm getting a lot of kickback when starting. I've checked the flywheel key and it's in tact and aligned correctly, I've checked the valve clearance and that was 0.1mm as specified and even inspected the camshaft to make sure the compression relief mechanism is working (it is).
Any other suggestions of things I should check?
Thanks
Richard
Scrubcadet10
Moderator
Staff member
.1mm is .003" ..... Seems a bit tight to me... Post up the model number... Should be stamped around the spark plug or muffler
Ex. 123456_1234-aa
Richard B
Ex. 123456_1234-aa
I've got JT-06-04-02 stamped above the valve cover - is that it?
Scrubcadet10
Moderator
Staff member
not finding anything with that. it will be in the format i posted the example in.
