Key switch question.
PTmowerMech
Cub Cadet ZTR
M# 01009444
S# 04033527991
Partstree keyswitch for this model (Cub Cadet 01003581) is like $50. Is there another brand or place to get these cheaper? Seems like the last one I bought was like $15.00.
Update: Is the 01003581 the same as the MTD 925-1396A ?
PTmowerMech
Most times if the pin positions are the same then the switches are interchangeable.
Just double check the kill wire does not connect to any power wire B A1 A2 etc before you fit it.
The Stens catalogue usually lists all of the OEM part numbers that it replaces.
