avoglade39
- Mar 6, 2013
- 6
- 11
I am looking at buying Kelvar deck belts . Does any one recommend them over conventional constructed belts.
Kelvar belts are generally used when you have a back side idler pulley... They will hold up to that type of wear a lot better than a regular belt...
Also if you are breaking your belts from shock at start up you may get more time from them than you do with regular belts...
Have you been breaking belts? :smile:KennyV
