kawasaki issues
kelly
I have an 07 cub cadet with a 22 hp Kawasaki engine. has been worked to death on our rough property. never failed because it do work to keep it in good shape. suddenly this season its working fine for 20 to 30 minutes and then I must pull the choke to keep it going and its difficult even then. let it cool off and it goes again. I went into the carb and it was as clean as new I went ahead and replaced a couple of o rings. same issue. then I replaced the plugs same issue. then I replaced the 2 coils. same issue. helpppppppp. thanks kelly
Sounds like a fuel blockage.
ut before you go racing off pulling the tank. invest in an in line plug tester.
pop it on the engine , ties out of the way and go mow.
When the mower stops or starts playing up look at the tester.
If it is flashing consistantly then you have a fuel problem.
If it is flashing randomly you have an electrical problem.
