bighawk316
I have an Exmark Quest 50'' deck with the Kawasaki FR691V and it is set to run at 3600 RPM's with no load but when the blades are engaged the rpm's drop down to 3300 RPM's. Is this a normal drop in RPM's under load or should the drop in RPM's be like 100 to 150 RPM's? I am wondering if it could be a governor problem and if it is how would I go about adjusting it?
Thanks In Advance For The Help,
Bighawk316 :smile:
Bighawk316 :smile:
