Rocket Surgeon
- Jun 17, 2020
- 23
Greetings to all, new member here.
I am working on a Kawasaki FR691V 23 hp 2 cylinder engine, and after dismantling it and removing the cam shaft, have found that the two lobes nearest the PTO each have a single ball-bearing on the bearing surface of the lobe.
I repaired a bent pushrod, adjusted the valve clearance, and reassembled the engine. When I started it, it ran roughly and smoked. I removed the valve covers, checked the valve clearance, and all looked good. As I cycled the motor by hand, and watched the valve train operate, I noticed a little "jiggle" in one of the cylinder's valve operation...instead of a clean opening and closing of the valves. Since I didn't understand this behavior, and it was smoking, I thought perhaps I'd broken a ring or skipped a tooth on the timing gear on the cam, or perhaps a damaged cam lobe...so I removed the motor and opened the case.
The good news...and the bad news, is....I see no damage inside, no metal flakes, cam and crank are aligned, motor looks brand new, and all is good.
At this point I'm not sure what is going on, but I discovered that the "bump" in the valve train is undoubtedly being caused by these ball-bearings on the two cam lobes. Perhaps used to pop the valves open prior to the normal valve cycle.
I'll post later on the underlying engine problem if necessary, but for now, can anyone tell me what these cam lobe ball-bearings are all about? I searched Google extensively and found nothing.
I can post a photo of the cam lobes with ball-bearings if helpful.
Thanks for any input.
