Kawasaki FR 691 V Using Oil
stan5686
I have a 2012 Toro ZTR with a Kawasaki FR691V 23 HP. engine. I have had an oil burning issue for a good part of the time I've owned it. Most of the smoke I see is on first starting up. Especially after an extended sit. The smoking on start-up makes me think of valve seals. I do see some smoke when running but just as a puff. Once I even fouled a plug from oil. Of course when still in warranty dealer said using some oil could be possible, but I never stayed on them about it and oil use has gotten worse. It has 170 hrs. I'm adding oil each mowing now. I haven't actually measured how much but it will use from full to add on the stick in about an 2 hours. I have read that some of these engines have had issues with oil getting into the intake through the breather tubes. Has anyone had this same issue?
Catherine
LawnWorld Support
Staff member
:welcome:
Welcome to the forum!
I'm going to move this thread over to our Kawasaki section.
cpurvis
Possibly a blown head gasket on that cylinder.
7394
Once you get a full heat in it, shut it down & remove dip stick, & see if you get any smoke out dip stick tube.
jcworks
Stan5686, I just read your post from 2019. What did you find out about your F691 engine? I have a 2013 models with 260 jrs. It's starting to smoke at start up. However, l just changed oil. Went from 10w30 to 20w50. I don't know if treats the issue or if I'm starting to have a problem like yours.
7394
jcworks- Stan has not been here since May 9, 2020, so you may get NO reply..
