Lawnboy18
 - Jul 14, 2013
 - 85
 - 1,451
What is the fly wheel key?
As for TDC, yes it was. I tried my best at getting it at close as possible to the spark plug hole. I then unscrewed the set screw, adjusted the adjusting nut and once I was done I tightened the set screw while holding the adjusting nut. Then I cranked it a little to check the clearance at different positions to see if it was still good. Is that fine?
Now, one of the screw holes to secure the valve cover is a little stripped. I am not very comfortable fixing this. This motor is really a headache.
