Travlitt
- Apr 13, 2013
- 5
- 34
I am having charging problems with this engine.
Question; AC voltage
1. When measuring the ac voltage coming from the stator, do you measure the voltage between the 2 white wires or do you measure the voltage from each wire to a ground point.
2.What is the acceptable low voltage and the acceptable high voltage?
Regulator.
Looking at the spades on the 3 terminal regulator, The 2 white wires terminals are molded together so they have to be connected to 2 spades on the regulator that are side by side. However the dc spade is between the 2 AC spades. So my question here , is this correct or what am i missing.
Regulator.
