Start with checking the valve lash as per the manual that you will find on either the Kawasaki web site on on this one https://mymowerparts.com/about_us.php
Yes, don't stick your dick in the flywheel...the valve lash affects when the valve opens & closes
The bigger the lash the latter the valve opens & the sooner it closes
This affect how much gets into the cylinder in the first place which will affect the final compression figures.
If your engine has ACR then too little valve lsh will open the cylinder for too long on the compression stroke again lowering the compression.
Because the compression is so dependent upon valve lash, a strait compression number is not much use.
Having said that anything less than around 60 psi & the engine will have difficulty starting .
Also they type of meter, how you do the test will also affect the reading.
A wide open throttle will reach peak reading in 4 to 5 cycles, a closed throttle can take 30 or more.
Remove the dip stick, turn the engine over by hand and listen for the sound of air escaping as the pistons approach TDC compression stroke ( watch the rockers to confirm this ) .
If it whooshes, or hisses then the head gasket is gone.
Do the same at the carb & exhaust, whooses at the wrong time indicates valve problems.
A leak down is a better test.
Also please be careful with your descriptions because all we have is the words you type
Turn over is considered to mean rotate not start or run.
It might hurt.....
Just put up a few pics....
Thanks! Lot of good information. I did hear the sucking of air when I was checking to see if the valves had movement but not sure where it was coming from.the valve lash affects when the valve opens & closes
Fat Tuesday is not for another few days??Funny you should say that .
It was mardi-Gras here last night
However I definately was not there.
Leather undies chaff way too much and sequined undies prickle.
You must be in Mobile.Funny you should say that .
Before you go any further I would whip out those guide plates clean them up & wack some paint on them.
I gather it gets a tad humid around your place with real cold nights & heavy dew.
SO some background might be good.
When did the engine last run ?
IS the loss of compression sudden or has it been getting harder to start for a while.
Also did you do the compression as per the manual.
You said you have worked on other engines so I hope that meas to rotated each cylinder to TDC compression before taking the readings & making the adjustments.
As for the plug, no colour is better than black.
If the engine is not running you will get no deposits on the plug.
If you have been cranking it for a while & it has not fired then the plug should be wet with fuel.
If not check the fuel cut off solenoid on the bottom of the carburettor.
If you get that much water in your rocker cavity chances are there is water in the solenoid & it has corroded closed.
Usually on engines with ACR's , you won't get an accurate compression reading, why? Because the compression release is doing it's job.
If you had a way to spin the engine at normal running RPM it would be accurat e.
I believe with compression releases it usually drops the pressure to about 80 or 90 pounds on most small engines.
https://www.youtube.com/watch?v=jc3j4ShE-tk
Beau Yes do a leak down test, that will tell you for sure the rings ore leaking VALVES..... Where you at down here in Mardi Gras country Mon Ami ~!~! ??????
Make sure when you do your tests that you have clearance between the valve stem and rocker arm. (To make sure the cam isn't holding a valve open.)
The air you hear going into the crankcase is going past the rings. This is a sign of wear. How many hours on the engine? Has the air filter been properly maintained?
The air you hear going into the exhaust (or intake) is air leaking past a valve. I can't speak for the FH601V, but the manual for the FR651V thru FR730V calls for "cleaning the combustion chamber, check and adjust valve clearances, and clean and lap valve seating surfaces" 300 hours. I can just about guarantee that 9 out of 10 owners are NOT going to do that and if they do, are smart enough to not do it in the order specified.
It might be that the 300 hour cleaning is to prevent the problem you're having. But it wouldn't have helped the rings.
Thanks. Yes I had clearance between valve stems and rocker arms and understand why the air is moving through the various parts.
Have no idea how many hours are on the engine but I can bet the valves and seats have never been cleaned or lapped. I guess I should pull the head and take a look at the valves.
Well down here head gaskets are only $ 13 each so why not.
Push rof engnes are so easy to do head jobs on it is almost a crime not to.
Yep that is exactly what a burned exhaust valve looks like.
Eventually it would make a V shaped crack in the middle of that flat spot.
It will need to be replaced.
If you have access to the tools, it is not a hard job.
If not take it to a mower repair shop, not a glass fronted mower retailer.
Most shops will replace the valve, clean the head & lap them in for a reasonable amount.
I charge 1/2 hour $ 30 + parts.
Not sure if yours has a seal on the inlet only or both inlet & exhaust.
If you want to do it yourself, buy a long 14mm x 1.25 bolt & a couple of nuts.
Thread the bolt through the spark plug hole & lock it with a nut either side
Then use this to hold the head in a vice while you attack the valves.
From the look of it something has dropped into the cylinder then got stuck under the head of the exhaust valve holding it open just a touch.
The actual damage looks exactly like what happens when a spark plug helicoil is used & the fitter loose the tang into the engine.
The next step is to get a new valve and feel how it fits in the guide.
It should rotate freely but not rock from side to side.
O small alloy heads like this one it is better to fit a sleeve in the guide than to replace the guide but either way that has to happen before the seat gets recut as the seat has to be true to the guide or the valve closes ( or rather doen't close ) at an angle and yo are back where you started.
Before you get too far, check the price of a new head.
Often the difference between a new head & a head job is marginal.
Thanks. Good advice on new vs rework. Around here small engine guys charge like attorneys so may end up being cheaper to go new.
