My Cub Cadet with a Kawasaki FD 590 V engine suddenly sent up a cloud of white smoke when mowing. It started OK and was running fine until I engaged the blades and that extra load resulted in loss of power and rpm and a cloud of smoke. I shut it down then restarted with the blades off and it seemed to run OK w/out smoke but as soon as I re-engaged the blades it started smoking and the engine lost power. I pulled the plugs and smoke came out of one cylinder. I am guessing the rings are bad on that piston, but I did not have the slightest issue before yesterday with it burning oil. So, I am wondering whether it could be something else like a blown gasket? Any ideas? If I need new rings how difficult and expensive is it for the parts. I have the tools except for the ring compressor.
