Good morning
I am working on an older Deere SX75 with the FC290V Kawasaki motor
While cranking my compression gauge shows 125# but as soon as I turn off the key the compression drops to zero
If the use starting fluid I can get the motor to start and run but it will not start without the starter fluid
I checked the head gasket (looks ok), set valves (4 & 5/1000)
Installed aftermarket carb - made no difference really
Cranking the motor without starter fluid seems to generate some backfire / misfire thru the carburetor also
It will run and idle fine, just does not seem to be able to draw fuel on its own
Is this normal for compression to drop as soon as the stater stops cranking the motor?
Any direction would be appreciated
TIA
TIA
