Grass Mower
- Jul 10, 2016
- 4
- 13
I have a late 1980s era John Deere SX95 riding mower with a Kawasaki FB460V single-cylinder, 12.5 HP engine that (gradually?) began to run rich in the last couple of months. It starts well, but has sooty exhaust and is rough at idle, and is even rougher under load, with poor power and poor response to throttle. The following is what I've done:
-New NGK-BMR4A spark plug, gapped 0.026,"
-Air cleaner cleaned, Compression tested = 87 psi.
-Good spark with spark tester; Coil measured & meets specs, gap to flywheel set,
-Valve clearance measured, both intake & exhaust are 0.005" (close to specs) at TDC,
-Oil changed; Fuel tank cleaned and fuel lines and filter replaced.
-Ignitor did not meet specs and was replaced with aftermarket brand,
-Disassembled and cleaned the carb twice, blowing out all ports with compressed air. Butterfly valve closes fully at choke position and opens fully in idle position. On the first cleaning, the float was elevated approx. 20 degrees to bowl mating surface when carb was held inverted, and I bent the clip to bring the float parallel. The needle valve had only a slight ring around it near the tip, but I later replaced it anyway. The air bleed (pilot) screw has a similar ring, was not replaced, and is backed out 1-1/8 turns, but turning it in or out doesn't make much, if any, difference.
None of these has made any difference, except for the development of lack of good throttle response during the time I was doing all this. I have not removed the flywheel to check the key. Could this be the timing is off? Can you tell that by the position of the magnet? See attached photo of magnet position at TDC.
Another question is about the positon of the float in the carb. I got a new spring clip with the new needle valve, and it had a 90 degree angle, which caused the float to be at a significant angle when installed (carb held upside down). Usually parts are supplied how they need to be used, not requiring much adjustment. I had to bend the new clip to get the float level again. Am I missing something here?
I hope someone can help, as I'm about to give up on this engine and ditch the mower.
